04-01-2011 01:02 PM
What is the best way to write to a control? Can this be done without the use of a property node?
04-01-2011 01:42 PM
generally writing to a control should only happen when setting up a screen or inititlaizing a display, in which case usinga local is acceptable provided you are control when it is occuring using proper data flow techniques.
Ben
04-01-2011 02:14 PM
Either property nodes or local variables.
However, be careful you are not creating any race conditions by doing so.
Generally, these options can avoided all together depending on your application (via shift register or something similar)
04-01-2011 03:55 PM - edited 04-01-2011 03:57 PM
using a local variable is faster in execution than a property node. and use a control reference to write to a control in a VI from another -
Cheers,
Mone
