Best Architecture for my application
Dear LabVIEW users,
I am currently developing a programm for a testing machine with Machine Vision. The machine consist of XYZ table, additional motors for micropositioning, two cameras, and some sensors. The main aim of the machine will be to enable the user to perform a test on a product, basing on image processing. The user should be able to start an automatic test (the table will move automaticly based on the image from camera, and sensors should obtain data during the test), or choose an option to manually move the xyz table and check the image from the cameras.
I have already developed some VI for usage of cameras, the actuators and so on. Now I am trying to build one application, but I am not sure which architecture will be appropriate. Do you think the Queued State Machine will be ok?
I have some experience with labview, but I have never built such a big application, hence my question.
Thank you very much for your tips.
Jolanta
Message 1 of 8
(5,159 Views)
You can use Master Slave architecture for your application. If your application follows a series of action then Queued State Machine will be fine
CLD Using LabVIEW since 2013
Message 2 of 8
(5,151 Views)
Queued Message Handlers (QMH) will be your friend.  Each instrument/device can have its own QMH to be controlled by.  You may need a main state machine to further tell the QMHs to do stuff.
If you want to go hard core into OOP, then have a good look at the Actor Framework.  It would actually fit pretty good here.
Message 3 of 8
(5,126 Views)
Of course you don't need to use any OOTB architecture.
Especially with OO, you can compose your application from objects, 'glued' together with patterns and\or synchronization objects.
I like it like that, as it gives me the perfect fit for each of my applications. But if you just want a quick start (at the expense of boilerplate code Smiley Tongue), you can of course use on of many frameworks.
And of course both ways have a learning curve, but for me doing it on a per project basis is something I've learned over the years. Learning XYZ framework takes time to solve a problem I personally don't have. That could be different for you.
Message 4 of 8
(5,077 Views)
Hi, thank you for your tip!
I am trying to understand a difference in performance between the Queued State Machine and Queued Message Handlers and I do not see it clearly. Queued State Machine can also have multiple queues and while loops for each device, controlled by one event structure, or not? Exactly like with queued message handler. What do I miss?
Thank you for your help!
Message 5 of 8
(5,051 Views)
I don't think you're missing something.
A SM (as we use it in LV) is basically a while loop with a case structure. States go from one iteration to the next in a shift register. A QSM has an queue of states, but is still a loop with a case structure. As you'd usually want to have parallel processors (that you could call "actors"), you'' basically end up with a mixture of SM, QSM, Actors, QMH, etc..
I'm not a CS guy, and I use more pragmatic designs for my architectures. But I'd say most "architectures" use other patterns as well. So, SM will use Actors, AF will implement (Q)SMs, etc..
And that's how it should be done: pick what you need. Or as I see it: pick the simplest solution that does the job.
BTW: Haven't used a (Q)SM in 10 years. If I need something like that, I prefer a state pattern. But even those a rare.
BTW2: I often use a loop with an event structure in my main VI. If something needs to be done in parallel, I start something in parallel. Don't really care what to call that "architecture". Probably an event handler, with some actors, mixed with a bit of (queued) message handler.
Message 6 of 8
(5,044 Views)
A Queued State Machine (QSM) is a single loop that uses a queue to hold its states that it will progress through.  NOBODY OUTSIDE OF THE QSM SHOULD EVER SEE THE STATE QUEUE.
A Queued Message Handler (QMH) is a single loop that gets a message (via a queue or the like), reacts to said message, and then waits for a new message to come in.  THE QMH SHOULD NEVER ENQUEUE A MESSAGE TO ITSELF.  Only other loops/actors/modules should tell the QMH what to do.  I will go ahead and throw in the grey area where the QMH does something based on a timeout (no message is received in X ms).  This is how I typically set up my instrument communications.  When commanded, start reading from the instrument and repeat on a timeout until commanded to stop.
So each architecture has its own uses and there is nothing wrong with using multiple architectures in a single project.  One of my favorite projects was based on a QSM to help the user through a process.  The QSM sent messages to several other QMHs that handled the instrument communications, error handling, data logging, and a few other minor things.  Those QMHs also send data to each other and back to the QSM using User Events.
Message 7 of 8
(5,036 Views)
Structurally, a QSM and a QMH might look very similar.  What distinguishes them for me is my *mindset* in how I think about them.   Quoting myself from over here:
Some essential concepts to distinguish a Queued Message Handler from a Queued State Machine:
- In a QSM, a case and its code define a state. States are what get queued up. A QSM will tend to linger within a state (or loop around to the same state repeatedly).
- In a QMH, action messages get queued up. Code for a message will execute quickly. A QMH will tend to linger at the Dequeue function, waiting for a message to act on. Data is what defines the operating state, usually held in a typedef'ed cluster and stored in a shift register.
This is largely similar to what crossrulz already said, just stated with different words with different emphases.   In the end though, what you call them is mainly a matter of communicating clearly with others.   The code doesn't care, it does what it does whether you label it or not.
-Kevin P
Message 8 of 8
(5,005 Views)
