02-28-2019 05:45 AM
Hi to everyone.
I would like to connect a basler camera which his interface is USB 3.0 in a USB 2.0.
Will NI MAX detect the camera?
There is any problem to conect the camera USB 3.0 to an USB 2.0?
Thanks a lot.
02-28-2019 08:47 PM
It should work, but won't be as fast. Color images take 4 bytes/pixel while B&W takes 1, the size of the Image matters, and the frame rate matters. If you are taking a single image, it might not matter, but if you want video, it probably will (because I'm guessing the camera's design needs the higher bandwidth of USB 3.0).
