Basic serial write and read
I'm back at a computer with LabVIEW and I see that you are sending \r\n after the command. What number do you get on the indicator connected to the Bytes at Port property node?
[Edit: And did you try putting a delay after the serial port configuration?]
LabVIEW 2012
Message 11 of 12
(491 Views)
@AO1212 wrote:
I did not originally have NI-VISA installed, but I did install it (version 5.1.2).  I did not try sending one character at a time, however I did try sending one bit at a time.  It did not make a difference.  I am also sure I have the correct port because it works when Highlight Execution is enabled.
You cannot send one bit at a time. What did you actually do?
Message 12 of 12
(484 Views)
