Basic question TDMS
i build a small datalogger. It works now fine.
 But i have a strange effect at tdms datalogging. It always stops at around 3h. Sometimes with error 6, sometimes not.
Samplerate is 100 and samples 100,too. So should be 100Hz.
Message 1 of 13
(4,563 Views)
What version of OS (32/64?)
File size after stopping?
And what file system?
You may have reached the file size limit in your environment.
upd:
Also show your source code if it is really small. Maybe there is some kind of mistake
Message 2 of 13
(4,553 Views)
I´m using windows 10 64bit professionell. Filesystem is NTFS?
Labview is 2016 32bit.
Filesize of tdms is ~15mb after ~3h
Message 3 of 13
(4,533 Views)
Hi Hulk,
You are constantly opening the TDMS file, but you are never closing the file!
Open the file once on "start logging" and close it once at "Stop logging", but use the file reference in between!
Btw. is there a reason to have a space at the end of the filename of "create path " VI?
Message 4 of 13
(4,527 Views)
Hi Gerd again,
You are seeing all, the space was not wanted.
I´m sorry but i didn´t understand
Message 5 of 13
(4,484 Views)
Hi Hulk,
Right now you open a new file ref with each iteration, but NEVER close all those references. Both is bad: no need to open so many references, and each reference you open should be closed too.
Simple solution: open the file once when you start to log data, and close the file once you stop the logging!
Message 6 of 13
(4,474 Views)
Note that you could use a shift register in the second loop, but since it's a reference it shouldn't matter for this case.
Message 7 of 13
(4,466 Views)
As a quick further note on references and shift registers:
  • While loops will always execute at least once. So a tunnel is fine provided you wire it through
  • For loops can execute zero times (depending on the way their iteration count is controlled - e.g. empty array set to autoindex). This means that the value out of tunnels is the "default default" for the type, which for a reference is invalid. So use a Shift Register with a For loop even with references if the number of iterations can ever be zero (even if you don't expect it to be zero).
GCentral
Message 8 of 13
(4,445 Views)
Hi guys,
i tested the version with permanent open and close the tdms file. That´s not possible. System performance is going down.
The second solution is not possible because i need to open the file inside of while loop. I´m sending the path from the event struct.
Any other solutions?
Message 9 of 13
(4,402 Views)
Naturally, it is crazy to open and close the file at every step.
It is very possible to open the file “before” the cycle, for this you need to learn two simple mechanisms: a state machine and a shift register.
Here are three cases in ONE loop. You do not need to do three separate cycles, I showed them only to understand what is happening in hidden cases.
Message 10 of 13
(4,399 Views)
