Basic multiple timer circuit
I'm new to labview and need some help with a basic circuit.
I would like to create a vi which will allow the user to enter a list of on/off times from the front panel to turn a single output on and off sequentially at 10 different time intervals. I've tried using the array function but got no where because I don't really understand the options. Any help or starting point sample vi would be much appreciated. thanks.
I'm using Labview 2010
(3,938 Views)
What you have tried so far? Can you  upload the VI.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,937 Views)
Accepted by Andy_K
How about this:
Example attached Labview v.2010 SP1
I used a while loop, feedback node and index array so that elements could be added to the array on the fly and the program would continue until it reached the end of the array, then start again.
If your situation is more static - i.e. you always have 10 values, you could easily cut all that and use a for loop.
(3,921 Views)
thanks danbrown I'll try it now, my non working attempt is attached Ranjeet
(3,916 Views)
