Barcode or QR code scanner
This Vi reads barcode form barcode scanner & checks it with compare string.
problem: The Scanner when scans barcode it is not reading full data.
sometimes 1 character
sometimes 2 characters
I am using USB barcode scanner.
it is working when I use it normally without selecting update while typing.
but I need it to work like when you Scanner scans barcode it should display it in indicator.
(715 Views)
remove the Wait and i'm sure it'll work better.
Qestit Systems
Certified-LabVIEW-Developer
(675 Views)
Accepted by Basavaraj093
Remove the "Reinit to Default" inside the event.
aputman
(666 Views)
