Ballard MIL 1553B Configuring as RT
HI,
I'm Using Ballard MIL 1553B
Model: 222-550-000
I need to create and configure a RT (RT address:2, sub address:1,word count:32) to send 32 bytes of data to external BC.
when I use examples (RT receive data example modified to send data/receive data) I'm not getting any kind of data in both in RX mode and TX mode also. If I configure it as BC instead of RT I can able to get a data (under MT mode).
I need a help to create and configure the RT as like as above mentioned
Message 1 of 11
(4,392 Views)
Is this related to LabVIEW at all?
Message 2 of 11
(4,382 Views)
yeah, Im programming in LabVIEW 2015 using Ballard 1553 API
Message 3 of 11
(4,355 Views)
You might be seeing a bug I ran into last year.  Astronics found an error in the DLLs.  I don't know if that fix ever got released.  They got me a beta version and it worked just fine.
Otherwise, I would need to see you code and configuration file (assuming you are using the XML configuration setup) to try to dig any more.
Message 4 of 11
(4,345 Views)
Pavithran111_0-1616389082064.pngPavithran111_1-1616389104585.pngPavithran111_2-1616389163984.png
Yeah I'm using XML file to configure the RT. I had attached the image my VI, XML config. and VIs
Message 5 of 11
(4,302 Views)
But your code is writing 4 bytes to RT 5 subaddress 16.  You need to update the rtAddress in the XML file to 2, the subAddress to 1 in the XML, and get RT index 2 from the array of RTs in the LabVIEW code.
Message 6 of 11
(4,279 Views)
Yes, I did that
even though I can't able to send or receive any data that's my problem. Im using multiple RT's In that this also a valid one.
This is the version on Ballard Driver I'm using for 1553
Message 7 of 11
(4,271 Views)
I have 2.12 installed and they had to send me an update for the BTICardLV dlls
Message 8 of 11
(4,265 Views)
Could you please share the driver or link to download that.
Message 9 of 11
(4,260 Views)
You can just go to Ballard's website, log in and download it here: https://www.ballardtech.com/support.aspx/myballard/.  The OmniBus II is listed toward the bottom of the page.
Message 10 of 11
(4,253 Views)
