02-12-2026 02:50 PM
Why is this still in the LV driver template?
At least they are not stacked on top of each other like they usually are in this one. 😋
agilent_3446x_series driver if you are interested. Specifically the "Public\Utility\Error Query.vi"
02-13-2026 07:35 AM
At some point, the Merge Errors was changed from a VI to a primitive (or maybe an XNode). The stacked up Merge Errors is an artifact of the conversion code. I would guess the cascading Merge Errors is from somebody just using the Diagram Cleanup and not looking at the results.
