LabVIEW: remote registry access denied.
I’m setting up a replacement PC.
The present PC is Windows 10 Ent. Installed on it is  LabView 2017 SP1 f4 (RTE) and the program that controls the instrument the PC is attached to.  This PC was supplied to us by the company that supplied the instrument.
Due to our updated Cyber Security Policy, I need to replace the PC. One that is Cyber Secure.
I have set the new PC up with my company’s PC image using Windows 10  Ent LTSC  21H2.  I installed LabView 2017 SP1 f4 (RTE) and then the required instrument program. The company that supplied the original PC and instrument sent me installation instructions to help with the install process.
After all the required programs are installed. I can open the Program.
When I go to save settings for the program, I receive an error:
Error -604 occurred at the create Registry Key.vi
Possible reason: -  LabVIEW: Remote registry access denied.
I have signed on to the new PC with my administrator credentials.  I have the same error. ☹
I raised to   Full Control    the folders:
           c:\Program Files (x86)\HDI
           c:\Program Files (x86)\National Instruments
           c:\Program Files\National Instruments
In services, I have  RemoteRegistry   set to always start
I have the same error ☹
I need help!
(2,398 Views)
Hi Aust,
I need help!
There are two parties that could help you:
  1. The provider of that software by changing its product to NOT write to the registry - or only use "accessable" registry folders. (Further testing required.)
  2. Your IT department by allowing more access to certain registry folders. This will reduce your "cyber security"…
The general recommendation is: don't use the registry to save settings of your (or your supplier's) software. Microsoft does/will apply more strict access rules than was applied at Win95 times!
(When your supplier needs ways to apply theft protection (aka license management) to their software then they should use some available 3rd party tools, like those from WibuSystems.)
(2,389 Views)
