Background image blocks control
I have a numeric control placed over a background image. Initially it worked fine. But after I reorganize the program, I found that the image blocked the control. If the control is in the border of the image, I can not change it. If the control is out of the image range, I can change it. How do I fix this? LabVIEW 8.6
Ryan
(3,293 Views)
Accepted by RyanWu
Sounds like you just need to reorder things.  Select the control, and then select Move to Front.
Alternatively, you could select the background image and select Move to Back.
Message Edited by elset191 on 10-26-2009 04:50 PM
Tim Elsey
Certified LabVIEW Architect
(3,290 Views)
The other option I would consider, if you truly want a "background" image is to add it by going to a scrollbar of the Front Panel, right-clicking and selecting Properties and choosing a image for the background.
Message Edited by Darin.K on 10-26-2009 04:56 PM
(3,284 Views)
elset191,
    It worked. Thanks.
Ryan
(3,261 Views)
