BUG: Nested cluster Value change events
@Darren wrote:
@mcduff wrote:
On the Front Panel, a value change on the Tree cannot occur without a Mouse Down Event.
While your VI is running, you can press the Tab key on your keyboard to set key focus on a tree control. You can then use the arrow keys on your keyboard to change the selected row (i.e. the value) of the tree control. No mouse interaction required.
This was meant as an example not an absolute. But you could always have the control skip tabbing, have a touch screen control with no keyboard, etc. This was only to show there is an event order, nothing else.
Message 31 of 37
(854 Views)
wiebe@CARYA wrote:
All your logic doesn't explain why this works for an element in a cluster (expected), but not for a cluster in a cluster (expected).
It's a bug and unexpected behavior.
Message 32 of 37
(848 Views)
I don't think we'll get to an agreement on this.
It doesn't matter anyway, little we can do about it.
Message 33 of 37
(832 Views)
I do think it is bug, but not for the same reason as you. Your example of an element in a cluster seems like a bug to me, it should work like the nested cluster.  😉
Message 34 of 37
(812 Views)
I do understand you feel that way, but I disagree.
Message 35 of 37
(805 Views)
This isn't politics or religion, it's fine to disagree.
This thread is going on too long and I and you seem tired of it. So let differences be differences, and there is a workaround. Have a flat cluster structure then your preferred execution occurs, put everything in a Matryoshka cluster and things will work in my execution order. 🙂
Message 36 of 37
(793 Views)
Yes, like I said: it's not up to us to change it anyways.
Or don't use clusters at all.
I find that clusters in UI's are very limited anyway, as controls and indicators can't be mixed. If there are a large number of controls\indicators, I go by reference...
Message 37 of 37
(786 Views)
