BUG - LabVIEW 8.6.1f1 event duplication
I have seen this several times since I upgraded to 8.6.1f1, but cannot swear it doesn't exist in 8.6 or 8.6.1.
Suppose you have an existing event:
And you wish to duplicate the event by choosing "Duplicate Event Case...".  LabVIEW displays the following:
You will notice that the Event Properties show a Disregard? in place of Source and then it indicates that all of the other event properties are invalid (black text), and the VI shows a broken arrow.  However, if you recompile the VI by running it or clicking the run button with the CTRL key pressed, it will update to be correct.
Message Edited by Matthew Kelton on 04-17-2009 11:50 AM
Message 1 of 13
(5,095 Views)
Here is the VI.
Message 2 of 13
(5,093 Views)
I see it in 8.6 but not in 8.5.1.
Message 3 of 13
(5,076 Views)
Hi Matthew,
This was reported to R&D (#161606) for further investigation.  Thanks for the feedback!
Message 4 of 13
(5,031 Views)
I have seen a similar phenomenon with UNBUNDLE BY NAME, as of 8.6.
If I have an UNBUNDLE BY NAME on the diagram, disconnect the input from one cluster, and connect it to another (of the same type), the outputs will turn black and be broken.
Simply popping up on one output and letting go will set them all where they should be.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 5 of 13
(4,947 Views)
Hi Steve,
Can you post a screenshot of what you're talking about?  I can't seem to replicate the bug.
Message 6 of 13
(4,910 Views)
I'll try.  It doesn't happen all the time.  It's not something I can do on command.  It has to do with the phase of the moon or the temperature of the room...
Steve Bird
Culverson.com
LinkedIn
Message 7 of 13
(4,908 Views)
ID #161606 is a duplicate of another report.  Please use ID #167072 for tracking purposes instead.
Angela M
Product Support Engineer
Message 8 of 13
(4,847 Views)
Hey Matthew!
This bug has actually been reproduced in 8.6 and 8.5.
If you could tag this post as the "Solution", that would be great; the forum readers will then know that this is not a bug in the 8.6.1f1 patch 🙂
Thanks!
Chris Bolin
LabVIEW Partner Program, CLA
Message 9 of 13
(4,778 Views)
Chris,
I am not sure if you read my original post (or even the subject).  This is occurring in 8.6.1f1 as well.  It still exists.
Message 10 of 13
(4,765 Views)
