BUG: Gauge
I added a gauge on front panel, change some properties and numbers and neddle are out of the circle.
Message 1 of 9
(4,052 Views)
Well, only you know what you did, but I was able to undo the damage. (Highlite an indicator, select "edit...customize control", and move the scale and hands back to where they belong.)
For the other two controls, just make a copy of the corrected one.
I'm curious. Do you have some details on which properties you changed, and how?
Message 2 of 9
(4,052 Views)
Cool! Had you customised the controls? What were the attribute changes you made?
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
Message 3 of 9
(4,052 Views)
Seems he used the property "scale.position:left", see example.
(Weird thing is that the default position is not zero.)
Message 4 of 9
(4,052 Views)
No. Im trying to replay the sequence to get this behavior
Message 5 of 9
(4,052 Views)
Yes, but I just used the properties window, and there is not left property there
Message 6 of 9
(4,052 Views)
I've seen upredictable scale placement scrambling before, so there might be a buglet in the LabVIEW code. Have you reported it to NI?
Message 7 of 9
(4,052 Views)
Have you been able to repeat the problem? If so, what steps lead to it?
Message 8 of 9
(4,052 Views)
No. Im trying to do so, but I cant
Message 9 of 9
(4,052 Views)
