‎10-18-2007 05:45 PM
‎10-18-2007 10:22 PM
Once upon a time, before networks were wired with UTP (unshielded twisted pair) cabling, they used coaxial cables and if you really have an Ethernet board, then the BNC is for compatiblity with these old style network connections. If the type of signal you want to bring into the pc is an Ethernet connection, then this card will work assuming that you have a sutitable hub to connect it to or another pc with the same type of connection.
If an Ethernet connection is not the type of signal you want to bring into the pc, what type do you want? Don't confuse the connector type with the type of signal.
‎10-18-2007 11:19 PM
‎10-18-2007 11:57 PM
‎10-19-2007 01:53 AM
