BAR Code QR Code Problem
Accepted by alialiali
Hi zah,
something like this:
Message 11 of 30
(3,414 Views)
yeah i understand what u mean
but when i try to do the same u r saying
i am getting error
like the snapshot 1 is the scanning of barcode.
in the true case, i remove the default wire
n then in the false case i am trying to do like u show me
i am getting an error with that
there is 3 unwired wire in this vi seen at snapshot 1.. 2 pink n 1 green
Message 12 of 30
(3,402 Views)
this one is the higlighted undefault wire
Message 13 of 30
(3,398 Views)
Hi zah,
until now you always wanted to save those "String barcode" data in your file.
Why don't you wire the string as shown above?
Why do you now bring that "Image ROI" wire into play?
Message 14 of 30
(3,392 Views)
Dear Sir
Thank you very much for the help.
Mr Qasim successfully did what you told us
now there is only a small issue where we are getting it repeatedly. I will attach the
snapshot along
Hope to hear from you soon
Message 15 of 30
(3,364 Views)
Dear Sir
snapshot along
Message 16 of 30
(3,366 Views)
Hi to all of you,
now you need to apply a condition, before you write new data to the file.
I would guess you only need to write data to the file, when both barcodes are read successfully…
How big is xyour group? Now there are 3 different nicknames discussing the same homework…
Message 17 of 30
(3,346 Views)
Dear Gerd,
First of all, thanks alot for your help. Yes, you are right that we need to apply some condition. But I dont know how to apply the condition. We are only two in this group. We will be really thankful to you in this regard.
BR,
Qasim
Message 18 of 30
(3,339 Views)
Hi ali,
two people with 3 nicks… 😄
Well, somethink like this pseudocode might work:
IF new QR code AND new barcode THEN warite new line
Message 19 of 30
(3,335 Views)
Hello sir
actually we are only two in the group.
when i open this page using mozilla firefox, the id is zah12
when i open with goggle chrome, i became zahkay
i dunno what is the issue
but what do u mean by the pseudocode
how the condition should be
since it is in labview. it should be in block diagram yeah..
pseudocode is not c coding
correct me if i am wrong.
hope to hear from u soon
rgrds
Message 20 of 30
(3,320 Views)
