Averages for number of loops
Returning the outer loop resutls in two rows of data which I am struggling to classify. Please see the attached
Islam means peace
Message 11 of 23
(1,155 Views)
Please attach your code so we can see what you are doing.
Message 12 of 23
(1,148 Views)
Here it is crossrulz. Thank you for your help.
Islam means peace
Message 13 of 23
(1,140 Views)
Sorry for the duplication in my reply
Islam means peace
Message 14 of 23
(1,140 Views)
Still waiting for it to be solved. Any idea?
Islam means peace
Message 15 of 23
(1,121 Views)
I still don't know what you want.
What is the meaning of "classified"? Since the x y data contains much more points than the averaged x y data, I still don't see how you want to squeeze it all into four columns.
Message 16 of 23
(1,116 Views)
Hi Altenbach,
Based on my experience, in some occasion you need to see the data of individual loop without averaging in case something wrong happened to any of the loops during the operation (although the averaging in most cases would be desirable) . And also to compare the behavior of one loop with the averaged one. So, the data come to me with this code is hard for me to extract the information that I am looking for.
So, I would like to have the data to be separated into four columns and saved to text file as I mentioned in my previous posts.
You are right that X and Y points will be more than the averaged points but that should not be a problem. The excel file at the end should contain the following information:
IN col. X                         Col Y                          Average X                          Average Y
N* 250 points           N* 250 points                     only 250 poins                    250 points
Islam means peace
Message 17 of 23
(1,112 Views)
So you really want 2*N+2 colums and 250 rows?
Message 18 of 23
(1,082 Views)
Hi Crossrulz,
If I set the outer loop to 3 (no. of loops), and assuming that the inner loop would give only 2 measurement points,  the data file should has the following data (just for example I use arbitrary numbers which may be generated by the random number generator)
 col. (1)        col (2)               Col. (3)                              col. (4)
 X                    Y                  ave (X)                                ave (Y)
 0.1                    0.3             (0.1+0.2+0.4)/3                (0.3+0.5+0.8)/3
 0.2                    0.4             (0.2+0.3+0.5)/3                (0.4+0.7+0.2)/3
0.2                    0.5
0.3                    0.7
0.4                    0.8
0.5                    0.2
Hope that expalins what I mean.
Islam means peace
Message 19 of 23
(1,077 Views)
Thanks. It really wasn't clear at all before. Try something like this....
 (EDIT: corrected mistake, please re-download attachment, now saved in LabVIEW 2010)
Message 20 of 23
(1,062 Views)
