Average of multiple array elements
I have 5 arrays of equal length, and I would like to take the average of each element and create a new single array of these average....ie average all 5 array element 0, average of all 5 element1, average of all 5 element 2 etc and write this to a new array.
I have tried the attached but without luck.
(5,628 Views)
Broken wires and the evaluation watermark makes it hard to see what is really going on.
You need a loop.  Try wrapping a For Loop around the Build Array and Mean functions.  Turn on auto-indexing tunnels for the 5 arrays going in and 1 array going out.  A For Loop with indexing tunnels is like a "For Each Element in Array" implementation.
(5,626 Views)
I tried that, it only created a numeric indicator on the output and not an array. Here is the code I have in place.
(5,613 Views)
Accepted by CastleWorks
Delete the scalar indicator.
Make all 6 tunnels auto-indexing.
Right click, Create Indicator on the output tunnel from the For Loop.  Now you have an array indicator.
(5,611 Views)
Thanks for the help, that did it.....it would not create an array indicator until I deleted the wire coming from the Mean VI and re ran it to the tunnel....essentially recreating it.....then it gave me the option of creating an array indicator.
Thanks!
(5,567 Views)
