Average Data
Sorry, I was being a narcisist, attached file may better suit you.  Yes, I plan to delete the beginning and ending data.
Thanks!
Christian
Message 11 of 20
(4,019 Views)
Hi cseamour,
try this:
Message 12 of 20
(3,985 Views)
Gerd, the ptbypt VI does not look forward as required.
Message 13 of 20
(3,963 Views)
But his current setup will do the 10 before, 10 after, and the current.  Somebody just needs to snip off the ends that are invalid.
Message 14 of 20
(3,957 Views)
That's what I meant. it requires some trimming and re-aligning of the outputs. In the current form it is incomplete.
Message 15 of 20
(3,951 Views)
Hi to all,
yes, my snippet does not "look forward".
I provide hints to the OP, but I leave them something to think about it! (And I never said that I gave them a complete solution!)
In this case it's a simple matter of counting up some elements of an array. I hope the OP can count, right now (s)he can still use all fingers and toes if needed for… 😄
Message 16 of 20
(3,937 Views)
Accepted by cseymour05
There are many ways to apporach this and the attached VI will show some possibilities (adapted from here)
The explicit subset average is probably closest to the desired functionality, it simply takes an average of fewer points near the ends, keeping the data size constant.
Here is a quick comparison. Modify as needed.
Message 17 of 20
(3,929 Views)
Thanks "altenbach".
Message 18 of 20
(3,922 Views)
Hi, I'm acquiring data from cRIO at 40Hz and put into a queue, the queue go to another while loop for calibration and write to text file. I attached the calibration for loop, I want some of the data written to file at 1 sample/second, the others at 40 samples/second. So, can I just add another for loop inside it and use the mean function to average 40 samples? Thank you, dude. average.JPG
Message 19 of 20
(3,753 Views)
Xiao@Gemini wrote:
Thank you, dude.
Nobody here is named dude and appending to a 4 year old thread that is already marked as solved does not seem to be such a great idea. Please start a new thread and attach your actual VI instead of a blurry and truncated picture. Why not just take the plain mean (i.e. not ptbypt) of the array?
Message 20 of 20
(3,746 Views)
