Automation Symbols Toolkit
My Automation Symbols Toolkit does not show up on the Control Palette under the User Controls. It is very tedious pulling the symbols from the Catalog Utility. How can I get the menus to install on the Control Palette?
(3,213 Views)
Try reinstalling the toolkit. Also, make sure that the version is up to date. It may be trying to put it in an older LabVIEW folder (//program files/national instruments/labview - instead of .../labview 6)
You can try to move it manually. Or, edit your palette, and add it to the menus.
(3,213 Views)
When doing the suggested re-install, make sure the option to add support for the version of LV you are using.
Ben
(3,213 Views)
