Automaticly Press Boolean
Hi all,
   Here I post the code  which I am doing  right.  I want to use PPT vi and CCD vi to make it work. Right now,there is a problem,I want to make CCD and the PPT talk in both sides. I want to when the Sequence loop in PPT can trigger the Start of Acquisition like real "press" the boolean button. When the slide changes, it will "press" the button. Thank you
(2,593 Views)
(2,567 Views)
