Automatically running a vi after switching tabs
You still have a basic lack of understanding. As mentioned, your case statement belongs INSIDE a while loop. Please take the tutorials.
You will learn some fundamentals and terms that you are currently using wrong such as running a tab or separating code with a tab. These are meaningless.
Message 11 of 13
(783 Views)
I forgot to add that wiring the tab control to the case statement is also backwards. You want the code to control which tab is displayed. These are fundamental concepts.
Message 12 of 13
(780 Views)
az2mt2003 wrote:
All I wanted to do, was be able to keep my code seperated using tabs. That may sound ridiculous, I don't know, I am fairly new to labview and I THOUGHT I had been using tabs the proper way. I guess not.
Tabs do not seperate code.  They break up the GUI.  If you actually want different sets of code, then you want to use a different VI for each section and use a main VI that uses a state machine to state which VI should run when.
GCentral
Message 13 of 13
(774 Views)
