Simple automated testing sequence
I have been a LabView user for some years now and I've got on reasonably well with it. I am now suffering from brain fade as I'm looking to implement a very simple VI to run an automated test.
I have a motor driving a shaft with an encoder to give me position feedback. I want to cycle the motion of the shaft depending upon the position of the encoder. My basic routine would be:
Run motor to end of shaft and stop when encoder output is a certain voltage. Run the motor to the other end of the shaft and stop when the encoder output is a certain value. It sounds very basic but I can't for the life of me work out how to get it running!
Any advice would be greatly received...
(4,015 Views)
Accepted by topic author ryouden
Hi ryouden,
as you want to cycle your motor you should start to implement a simple state machine: init, homing, move to end, move to start…
(4,007 Views)
Thanks GerdW,
I found an online tutorial and it worked out great.
Richard.
(3,981 Views)
GerdW,
One more question for you, how can I count the number of times I execute a certain task in teh state machine? I have implemented a number of Case Structures and I'd like to know how often it is executed?
Richard
(3,969 Views)
Hello ryouden,
you can increment a counter within the appropriate state and store its' value in a shift register.
Kind regards
(3,966 Views)
