Automatically resize cluster based on number of elements within
If anyone is curious how this was solved, see this post.
http://forums.ni.com/ni/board/message?board.id=170&message.id=405986&jump=true
Phil
Message 31 of 32
(1,595 Views)
As a follow up to one of my later question, I've been able to use scripting to change the representation of a control dynamically.  This is done when the numeric control (and the VI it's within) is in edit mode.  The section of code I have highlighted is what I added to the example above.  I have attached the VI as well.  (VI filename does not match the filename in the image... sorry!)
Thanks to everyone who helped out.
Phil
Message 32 of 32
(1,535 Views)
