07-31-2007 08:26 AM
Solved! Go to Solution.
07-31-2007 09:22 AM
hi there
sorry, i can't confirm this with LV 8.20 XPSP2 (Password has been applied to all VIs after doing the build).
Please check for
- make sure to apply the password to ALL VIs and the dependencies at "Build Spec."->"Properties"->"Source File settings"
- The locked VIs are saved in the builds directory and NOT at the original location. The original VIs remain unlocked
- If a single VI is unlocked all other VIs from the build are unlocked too, so you don't need to supply the password for each VI
07-31-2007 10:12 AM
- I think I do have the password applied to all VIs and the dependencies.
- I am expecting the password protected VIs to be in the build directory and not the original location.
- I checked the protection property of the VIs in the build directory. Only My top level VI is password protected. None of the dependencies VIs are protected.
Andy
