Automatic timed Boolean Control
Hey,
I have what I hope is a simple problem. I want to be able to control the boolen input to my case structure with "knob" inside it. I want to be able to have the input  held at "true" for x amount of time and held "false" for y amount of time. In addition to looping over "true"/"false" z number of times. Im fairly confident on the last part but I cannot find a way to alter the boolean states over a timed basis.
I have attached the Vi
Adam
(4,330 Views)
Hi Adam,
what time intervals are you talking about?
Some pseudocode:
FOR i:= 0 to z-1
  input := TRUE
  wait(x)
  input := FALSE
  wait(y)
NEXT
(4,320 Views)
Say, 5 minutes true, 20 minutes false? Its to control the position of a servo motor between two different positions.
Your pseudo code is exacty the behaviour Im looking for. Is there a way to turn this into a boolean input for a case structure?
Adam
(4,288 Views)
Accepted by flemingsta
Hi Adam,
I would use a statemachine: your problem reduces to just two states...
(4,280 Views)
Thankyou very much. it worked great!
(4,242 Views)
