Automate VI development
Is it possible to automate VI development ? I could see that we can create VI code manually using VI scripting but I want to convert C code to VI code automatically.
Please advice.
(5,735 Views)
One method is you can build c code as dll and call using Call Library function Node.
More info: https://forums.ni.com/t5/Example-Code/Calling-a-C-built-DLL-in-LabVIEW-to-Generate-and-Sort-an-Array...
uday
(5,722 Views)
You should be able to write a VI that analyses C and creates a similar VI through scripting. It'll be quite some work, but it'd work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(5,702 Views)
This post sonds a lot like this one.
Ben
(5,657 Views)
