Auto adjust Table column width
Hello ni,
                 Happy new year...  i am doing application with sql data base, for report i  made a table on labview. when i select the different query it will retrieve the data accordingly.
here i want to adjust the column width according to header name. is there any option for ?
or want to do some logic?
Balaji DP
(8,133 Views)
There's a JKI RCF plugin for that.  You ought to be able to get your answer by inspecting that code.
Jim
(8,119 Views)
hello, i installed the JKI plugins and copied this llb files in to jki/rcf/plugins folder..... but i cant able to understand how can i integerate with my code....?
Balaji DP
(8,088 Views)
Accepted by topic author Balaji_DP
Like this 😄
Jim
(8,066 Views)
Oops.  My answer doesn't limit the autosizing to the column headers.  Add this constant to the sub-VI (or, you can remove the inner For Loop).
Jim
(8,044 Views)
