Audio to binary signal
I am trying to convert audio signal to binary signal of 1-D array using the attached block combination.
Message 1 of 9
(3,953 Views)
Cifer,
And what is the problem?
I simplified your VI like this:
Which kind of "binary signal" do you expect?
Message 2 of 9
(3,946 Views)
Message 3 of 9
(3,922 Views)
I am getting a dimensional array of 66147 rows and 16 columns. But I want to reduce it to 1 Dimensional array of single row and 1058352 columns.
Message 4 of 9
(3,913 Views)
That's because your sound is 16bits. You can reshape it to a 1D array with a length corresponding to the product of dimensions, but I still don't see the logic behind all that.
Message 5 of 9
(3,900 Views)
I want to convert it to 1D array so that the individual bits can be compared with a threshold of 0.5v to generate a BPSK signal.
Message 6 of 9
(3,898 Views)
You could help us out by Googling audio bpsk and give us a few links that describe what you are trying to do.
Bill
CLD
(Mid-Level minion.)
Message 7 of 9
(3,888 Views)
Hi Cifer,
please talk with your classmate - (s)he should have already solved that problem
Message 8 of 9
(3,881 Views)
A "bit" only has two states: on or off. There is no "threshold" for a single bit. It really does not make a lot of sense.
Message 9 of 9
(3,877 Views)
