01-27-2019 04:27 AM
Hi everyone i have a text file which contains the date,time,voltage,current,power,imorted energy ratings of my Modbus Power meters. I used the write to delimited spreadsheet to write all the readings i received from the meters. The energy ratings of the meter is cumulative and i would like to be able to have a "search engine" that allows the users to view their energy consumed between any period of time. They would have to enter the start time and the end time that they want to view. For example if the user wants to view the energy consumed from 9 to 10 am the user has to enter 9am at the "start time" & 10am at the "end time". To get the amount of energy consumed i would take the imported energy value at 10am(from the text file) and subtract it with the imported energy value at 9am(also from the text file). Any help would be appreciated!
01-27-2019 05:19 AM
Sorry for the typo error in the title of the post. i meant to use "Read Delimited Spreadsheet.vi"..
01-27-2019 08:32 AM - last edited on 04-05-2024 01:40 PM by Content Cleaner
You should consider using SQLite instead of a simple text file. You could then also consider a more sophisticated UI: how about a chart of a day's power use, averaged over the last 30 days, say?
01-27-2019 09:13 AM
Hi drjdpowell thanks for your input, do you mean that the SQLite can do the "Search Engine" function that i am looking for?
01-27-2019 09:31 AM - last edited on 04-05-2024 01:40 PM by Content Cleaner
Hi Edmund99, SQLite allows the access to diferent databases, for LabVIEW drjdpowell has an API for easy manipulation: https://www.ni.com/en/support/downloads/tools-network/download.sqlite-library.html
When you store information with databases you can make queries involving the data in each field (Column) of this way to retrieve information like you described is easy.
You only need to learn how to write the queries but often it is intuitive.
01-27-2019 09:59 AM
SQLite uses SQL, Structured Query Language, which is used by databases for "Search Engine" stuff. There is a learning curve, but SQL is very highly capable.
01-28-2019 11:21 PM
Oh I see, thank you drjdpowell and everyone else! Will take a look at it
