Audio Amplifier Problem
Hello guys,
I would like to acquire sound via B&K microphone and get the SPL and frequency. There is a constant background noise in the lab as in the attachment. When I run the vi I got nearly 60Hz frequency result for the background noise. I used a frequency generator application and tried 400-500-700-1000-2500 Hz but got 59.9893-59.9868-59.9934-59.996-60.0044 Hz. I have B&K 1704, CCLD is on, and the gain is x10. I could not understand why I get the wrong frequency results. If you can help I would appreciate it. Thanks
Message 1 of 8
(3,113 Views)
Unfortunately I cannot tell how the DAQ assistant is configured (I don't have drivers installed, so the panel does not open for me). Also, the use of dynamic data hides important information.
What is the purpose of the FOR loop?
Maybe you need more advanced processing than to simply get the dominant component. How many points are in the data?
Message 2 of 8
(3,082 Views)
@altenbatch thanks for the reply. Honestly, for loop doesn't have an important purpose. I use the vi without the loop also.  The samples to reas is 441k and the rate is 44.1 k.
This's my first project so I'm a freshman.
Message 3 of 8
(3,026 Views)
OK, so you have 10 seconds worth of sound data. Are the frequency components constant for that duration or can they change? Have you looked at the magnitude spectrum to see all the frequency components. Maybe you can just ignore the 60Hz and look at the rest of the transform. If the sounds changes over time, maybe you need JTFA.
Message 4 of 8
(3,010 Views)
Any chance your electrical connections are wrong or due to inadequate shielding you are picking up 60Hz AC power line noise?
You would not hear this component since it is purely electrical 'noise', not actual sound.
-AK2DM
Message 5 of 8
(3,006 Views)
Agreed, but since they said "There is a constant background noise in the lab", I assumed it is audio noise (that might still originate from the net, of course). We also need to assume this is in the US. Other parts of the world run at 50Hz.
To the OP: can you attach the sound as e.g. a wav file instead of MP4?
Message 6 of 8
(2,968 Views)
The sound clip sounds like a fan or ventilation noise. Try a Lowpass or bandpass filter.
Qestit Systems
Certified-LabVIEW-Developer
Message 7 of 8
(2,932 Views)
Thanks for the reply. Most probably this 60 Hz is power line noise. The signal conditioner has red lights. I have checked and tried different BNC cables. I think not the wiring but the sensor has a problem.
Message 8 of 8
(2,885 Views)
