11-29-2011 04:30 PM
(Wrapping my head in duct tape)
Thinking out the most scaleable solution for a system that operates on "Widgets" by interacting with each "Widget cell" through "Gizmos". The path i'm thinking is the create "Widget cell" and drop it in 1-n subpanels. Easy right? just set Widget operator.vi" to reenterant (pre-alocate clones) and the GUI runs all widgets it is configured to run. the problem is the resource "Gizmos" will need to be re-enterant too (Share Clones) so that each widget operator associates with a unique gizmo resource module and the gizmos operate in their own space sharing memory between sucessive calls to the resource module.
The trick is what happens to gizmos clones? Does preallocating the spaces for widget operator also create a clone of gizmo or are all gizmo vi.s going to share space unless a larger clone pool is needed because of collisions? That would be BAD. Or is the correct approach to also prealocate gizmo.vi but, through some means force all calls to gizmo from widget operator to share the same clone copy?
Solved! Go to Solution.
11-29-2011 06:37 PM
I can't say this is your most clearly-written post, to the point that I can't quite rephrase what I think you're trying to do (is there a 1:1 mapping between widgets and gizmos?), but I think I can answer your question. You're asking about putting a reentrant (share clones) VI - I'll call it "share.vi" - inside a reentrant (pre-allocate clones) VI - which I'll call preallocate.vi. When you create multiple copies of preallocate.vi, you want to know, will you get pre-allocated copies of share.vi? No. There will be a pool of share.vi copies, and new copies will be created only when all existing copies are already executing. You won't be able to guarantee that a given copy of preallocate.vi will always call the same copy of share.vi. If you need all copies to share some critical piece of information, you can use a non-reentrant VI (perhaps a functional global) to store it.
11-29-2011 07:33 PM - edited 11-29-2011 07:36 PM
Thanks nathad-
That's pretty concise. Gizmo.vi is in fact an action engine doing I/O with a widget. I was hoping to avoid telling "widet operations.vi" Which one of several potential widgets it was working on to decouple it from hardware configuration and allow access to multiple identical hardware resources without copying gizmo.vi or jumping through hoops to dynamically call the right clone of gizmo from the instance of widget operations. It looks like I'll need to pass in the VISA session into Gizmo.vi rather than store it in clones of the AE and live with the blocking between widgets
11-29-2011 07:43 PM - edited 11-29-2011 07:45 PM
of course- if it was "Gizmo.vit" .... would that help?......
Some days I just don't know enough about LabVIEW![]()
11-30-2011 01:51 PM
That's a good question... I don't have a lot of experience with VITs, but I think that might work. There's some comments about VITs versus reentrant VIs here, but what strikes me as the key statement for you is "A VIT, on the other hand, is like a completely separate VI." Sounds to me like that's pretty much what you want.
12-01-2011 01:04 PM - edited 12-01-2011 01:05 PM
I was looking for those references! Thank nathand- I knew there HAD to be a way to do it![]()
Gizmo.vit is working nicely as shell demo code.
