At-dio-32HS
paolo5
Member
At-dio-32HS
Hi to everyone, I own the card AT-DIO-32HS but when I move it from a
computer to another I didn't find AT-... between the options in the
MAX it only appears the AT-DIO-32F.
WHY did appen?
Have I find the proper driver?
Thanks Perseo
4 REPLIES 4
bman
Active Participant
Re: At-dio-32HS
Perseo
Make sure that you have refreshed MAX after you have placed the AT-DIO-32HS board in the computer. You can do this with the F5 key. If this does not work, delete the AT-DIO-32F entry in MAX and refresh again.
There is a possiblity that you have a bad installation of MAX. If refreshing MAX does not work. I would suggest to uninstall NI-DAQ though Windows Add/Remove Programs utility, download the latest version of NI-DAQ from this website and reinstall it.
Let me know how it goes.
Brian
Highlighted
paolo5
Member
Re: At-dio-32HS
bman wrote in message news:<506500000005000000F16D0000-1017707437000@exchange.ni.com>...
> Perseo
> again.
> Brian
Oh, NO.
I re-put it on the first Computer and it functions.
It appears automatically on MAX as At-DIO-32HS but when I've insert it
o
n the second computer I didn't find it and I wasn't able to configure
it.
I reinstall Ni-daq 6.8.0 and after NI-DAQ 6.8.1, but is was useless.
What do you advice to do
Perseo
bman
Active Participant
Re: At-dio-32HS
Perseo
Here is what I would suggest, it may take a little while, though may do the trick.
1. Go to Windows Add/Remove Programs and uninstall NI-DAQ
2. Click on the Start button the Run, type in regedit. This will open the Windows Registry Editor. Follow this path to the NI-DAQ folder. HKEY_LOCAL_MACHINE >> Software >> National Instruments >>NI-DAQ. Delete the NI-DAQ folder.
3. Take the board out of the computer, make sure it does not appear in Device Manager anymore.
4. Download and install NI-DAQ 6.9.2 from ni.com
5. After NI-DAQ 6.9.2 has installed completely, place the board back in the computer.
This will usually fix issues like this, let me know if it does not.
Brian
EKarplus
Member
Re: At-dio-32HS
Another good resource is the Data Acquisition (DAQ) Installation/Configuration Troubleshooter:
http://www.ni.com/support/daq/daq6.htm
Hope this helps,
Eric
