09-18-2009 12:38 PM
09-18-2009 03:20 PM
Hello jstrong,
Please open the Microsoft Word Requirements Gateway example project located in the Requirements Gateway directory under <Requirements Gateway>\Examples\Word\Word Example.rqtf
You should be able to use this project along with the example word documents to get a better understanding of how to set up your own project.
Hope this helps!
09-21-2009 07:27 AM
Thanks for the info! Can you tell me if the custom style should work in a Word table?
09-21-2009 10:39 AM
jstrong -
You could customize the Word NIRG Type to add a new Requirement element which uses a regular expression to parse Table information.
When you include requirements in a Table, NIRG parses that information into the intermediate file in the form of |d Requirement_ID REQX: blah, where "|" specifies the beginning of a new cell in the row and d specifies the cell number.
Please take a look at the attached project which is a modification of the NIRG Word example. You'll notice that I use a custome Type called Word1 to load the Word Example - Requirements.doc file.
Hope this helps!
