07-25-2024 10:57 AM
So, I am dabbling in the world of JSON using the JSONtext VIs from JDP Science. In my very simple example, I have a first name, last name, and a date of birth which I think I have formatted correctly. When I run my VI, I can't seem to extract the data via my simple JSON string and end up with an error:
Since this is my first time working with JSON, I don't know exactly what the problem is. I'd appreciate the assistance of what to look for.
The VI that is attached should be down converted to v18.
07-25-2024 11:32 AM
You need quotes around the date. Even then, I am getting a different error (Not a supported timestamp format). I'll have to dig in order to get to the bottom of that one.
07-25-2024 11:50 AM
Date/Time stamp must be a string in ISO8601 formatsanto_13_0-1721926137325.png
07-25-2024 12:27 PM
Hmmm, I wonder why the date that gets returned from the date time constant returns 8:00:00 PM? I am in the Eastern Time Zone.
07-25-2024 12:30 PM
Eastern Daylight Time (EDT) = UTC-4:00 => 12-4 = 8
07-26-2024 07:50 AM
Santo - how did you know that the JSON dates need to be in the ISO format you linked? That link you posted appears to go to Wikipedia. Is there a website of whitepaper that speaks to that?
Perhaps it is in there and I just skipped over it.
Eric
07-26-2024 08:14 AM
The way I figured it out was a mix of experiment and experience but not through documentation.
From using JSON extensively in Python, typically, the ISO format is used. I tried the "Anything to JSON" VI with Timestamp data and the JSON text obtained showed the familiar ISO format with T and Z characters.
https://docs.jsonata.org/date-time
07-26-2024 08:26 AM
If you look inside the 'To JSON text' and 'From JSON text' functions, you will find calls to a dependent JDP Timestamp Library that describes the string formatting as RFC 3339.
JSON has no native timestamp data type.
