03-05-2014 02:26 PM
I am trying to create a Labview that will allow me to enter the name of a string which will correspond to two constants of my choosing, a and b, which are numbers.
I can not find a solution to my problem, I do not want to find the equivalent of my string in numbers.
The string would be something like Helium. Inputing helium would correspond to a value of a=4 and b =2
I need to do this for 5 more string inputs with different a and b values.
Does anyone have any guidance as to where to find instructions on how to do this or maybe you even know the solution?
03-05-2014 03:15 PM - edited 03-05-2014 03:17 PM
Welcome to the NI forums! your problem can be easily solved in many different ways with LabVIEW ....
show us what you have done so far?
03-05-2014 03:25 PM
It looks something like this, but I have not done it correctly. Currently I have no sub vi that works at all yet. I need where it says helium to be an input which corresponds to a string name. From that string name I need to find a way to import different a and b values. This is just a rough skeleton of where I am trying to get if I insert the a and b values as inputs. Does that make sense?
I am in an introductory engineering course and we use labview to solve problems, but they do not want me to manually input the a and b every time. Rather I need to only input the Element name, Specfic Gas Volume, and Absolute Temperature.
03-05-2014 03:50 PM
Create either an enum or a ring control that has the names of your elements.
Create a 2-D array constant. Column 0 is your A, column 1 is your B. Each row represents an element from your enum or ring constant.
Wire the enum or ring constant to an Index Array for that array constant, you'll get a 1-D array for that corresponding row. Then index array on that to break out the A value and B value.
03-05-2014 04:14 PM
I illustrated RavensFan's explanation below. However, I created an array of clusters instead of a 2D array to make things a bit more readable.
03-05-2014 04:51 PM
Wow awesome you guys were a great help!!!
Now to get this thing to work output and calculate like it is supposed to, which I should be able to figure out from here with a little trial and error. Much appreciated!
