Arrays
I have 2 input 1d arrays
Array1 = 1,2,3
Array2 = 4,5,6
what operation should i perform to get Output array in 1d array form as
output array =  1,2,3,4,5,6
Message 1 of 13
(5,016 Views)
Use the
Message 2 of 13
(5,011 Views)
Use the "build array.vi" right click and select "concatenate inputs"
Message 3 of 13
(5,008 Views)
Does anybody read manuals these days?
As has been indicated to you before: To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. There are also several Technical Resources. You can also take the online courses for free.
Message 4 of 13
(5,002 Views)
Many people don't read manuals.  Some are even proud of the fact that they don't.
Message 5 of 13
(4,992 Views)
We should have an international "nobody will answer questions on forums when the answer can be found in manuals". Let's make it in 2012. Then we can guarantee that the Mayan prediction of the world coming to an end is indeed true.
Message 6 of 13
(4,990 Views)
I thought we are the manual .... 😄
Message 7 of 13
(4,986 Views)
Yeah, but you know, sometimes it gets a bit tiresome sometimes.
Just sometimes.
Message 8 of 13
(4,982 Views)
Note that the Mayans didn't make that prediction; crackpots came up with a goofy misinterpretaion of the fact that the cyclic Mayan calendar will recycle in 2012.
Message 9 of 13
(4,973 Views)
Never knew that. Interesting.
Crackpots and goofy. Two words that go so well together. Like peanut and butter.
What were we talking about?
Message 10 of 13
(4,968 Views)
