Array with string and numeric column
Hello everyone. I'm a new labviewer, so i have 2 basic questions.
1. I found that basic stopwatch loop, which i have to move inside my event structure. How can i wire that loop together with my write and read ?.
2. I have to wire my "Elapsed time"numeric indicator with my array, so i want the "measurement" in the first column, and the "Elapsed time" in the second column. I know that i can't mix string and numeric indicator in the same array, so would the best way be, to make two 1D arrays (numeric,string), or there are more basic ways to fix the problem?.
Thanks in advance
Oesen
Best regards
Oesen
Message 1 of 10
(5,442 Views)
build a 2d array with your 1d array information and store it on a shift reg (note: the thickness of the Array data lines)....
Message 2 of 10
(5,431 Views)
I'm not sure what functionality you're trying to implement with the elapsed time loop.   I moved your timer inside the first loop and converted the time from a number to a string.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 3 of 10
(5,424 Views)
I have the 2010 version of Labview :(. Can you convert it ?
Best regards
Oesen
Message 4 of 10
(5,419 Views)
To create an array with mixed datatypes, you can make a 1D array of clusters.
Here's a simple example (LV2010 (snippet is 2012)):
(also note that this idea would really help :D)
Message 5 of 10
(5,409 Views)
Accepted by topic author Oesen
2010:
Message 6 of 10
(5,390 Views)
Exactly what i want.. Thanks for helping vt92!
Best regards
Oesen
Message 7 of 10
(5,375 Views)
Is there someone kind enough to convert again the update of VT92 into LV 2009...Smiley Embarassed
I'am facing more or less the same problem, and would be very interested in seeing the proposal...
many thanks in advance !
Antoine
Message 8 of 10
(5,302 Views)
Here you go
Message 9 of 10
(5,299 Views)
Thank you very much !Smiley Happy
Message 10 of 10
(5,293 Views)
