Array with Fibonacci numbers
Okay, a Leonardo of Pisa Challenge -- Write a function that takes an integer N and returns Fib (N) using the slightly-revised defintion:
   Fib (N) = 0, N <= 0
   Fib (N) = 1, N = 1
   Fib (N) = Fib (N-1) + Fib (N-2) otherwise.
Return Fib (N) without internally calculating and saving Fib (1), Fib (2), ... Fib (N-1) -- use only the definition above for Fib (N).
Warning -- the size of Fib (N) and the time to compute it (under the terms above) increase exponentially with time.  Hint -- Wiebe.
Test Fib (N)Test Fib (N)
Message 21 of 30
(2,604 Views)
wiebe@CARYA wrote:
I'd do recursion:
When I said that, I mend "I'd do recursion to impress the teacher"... Otherwise, pick the simplest solution.
Message 22 of 30
(2,596 Views)
@jamiva wrote:
Here is another implementation without any case structures or BuildArrays. Works for F0, F1,... to F93
I'd prefer the Min & Max with 93 over the In Range and Coerce. The results would still be valid for <0, AFAIC.
Other then that, I don't think it will get much better.
Message 23 of 30
(2,596 Views)
   Fib (N) = 0, N <= 0
   Fib (N) = 1, N = 1
This might be cheating... Not sure which rule I broke though.
Message 24 of 30
(2,588 Views)
Thanks!
I will improve  Smiley Happy
Message 25 of 30
(2,574 Views)
I'd say y = 0,4414e0,4817x for x>=2
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 26 of 30
(2,563 Views)
Wiebe -- You 'da Man!  I didn't think to bring out Fib (N-1) as a "helper" output (which accounts for the exponential Time of my code, and the incredible speed of yours).  I love recursion, though it does have traps "for the unwary" (such as I).
Message 27 of 30
(2,557 Views)
/Y
nice
Message 28 of 30
(2,553 Views)
So I didn't cheat Smiley Surprised?
(It actually freaked me out a bit that it worked.)
Message 29 of 30
(2,550 Views)
don't forget about the infamous formula node
Message 30 of 30
(2,548 Views)
