Array to spreadsheet problem
Hi Oesen,
so we will read the specs aloud together:
Data rate range using internal master timebase: Minimum 1.613 kS/s, Maximum 50 kS/s.
The data rate must remain within the appropriate data rate range.
Please repeat those sentences!
Message 31 of 45
(1,457 Views)
So my sampling rate can't be below 1613 ?
Best regards
Oesen
Message 32 of 45
(1,452 Views)
Hi Oesen,
so we will read the specs together again:
Data rate range using external master timebase: Minimum 391 S/s, maximum 51.36 kS/s.
Why do we have to repeatedly read that specs together? Aren't you able to do this on your own? Or even call the NI support and talk with them about that problem?
Doh...
Message 33 of 45
(1,448 Views)
Hi GerdW
The problem is that those values don't make any sense, when i use them in my VI. I have changed the Vex Source to External and changed both my rate and number of samplings to 391, and i don't still get 1 measurement every second.
Best regards
Oesen
Message 34 of 45
(1,444 Views)
Hi Oesen,
what's your external master timebase?
Let's read the specs together:
Data rate (fs) = fm / 256 / n, with n as integer in the range of 1..31
Please provide all information needed to answer your questions. And RTFM!
Message 35 of 45
(1,441 Views)
Sorry if i'm being annoying.
I'm using a external Vex Source and my minimum sample rate can be 391 S/s
I know that the goal for this formula is to show the data range with using the integers from 1 to 31.
31 gives the minimum value, and it gives the sample rate 391 S/s yes, but the maximum frequency timebase is the only unknown value in this formula. Should i find this one ?. Is there a relationship between "number og samples" and f.m ?
Best regards
Oesen
Message 36 of 45
(1,435 Views)
Hi Oesen,
your voltage source has nothing to do with time master base for sampling. As long as you use internal time base you're limited to 1631S/s minimum!
Message 37 of 45
(1,430 Views)
Do i have the opportunity to swtich from Internal to External. If yes, how do i do that ?
Best regards
Oesen
Message 38 of 45
(1,425 Views)
In the DAQmx you have that option in advanced timing.
Message 39 of 45
(1,421 Views)
Hi Oesen,
I would use the "DAQmx Timing" function...
Message 40 of 45
(1,418 Views)
