Array to cluster booleans? bits?
I was trying to *make* a cluster in as little space as possible and tried to build an array of 3 booleans and then use the array to cluster function to make this cluster.  however, it seems that there is some fancy way labview is handling the booleans.  something like an 9-bit thingy?
A long time ago I remember reading about how hardcore CS people interpret bits... little big endianness? I've also seen how labview can convert some integer into a 9-bit thing like this.
Anyways my question is, is it possible to make a "cluster of 3 elements" from 3 boolean constants without having to use "bundle"??
Thanks.
Message 1 of 12
(4,240 Views)
Hi Engineer,
maybe you should do what your nick implies: reading a manual…
The help for ArrayToCluster describes the functionality clearly. And it mentions a right-click option to set cluster size… (Doh!)
To put it in popular words: READ THE F*** HELP!
Message 2 of 12
(4,223 Views)
Accepted by BigShotEngineer
The Array to cluster defaults to 9 elements, r-click it to change.
(As a side note LV implements booleans as U8, so a byte for each. If you want bit optimization you could mask it all to a single U8 as flags - C-style)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 12
(4,187 Views)
Ah, fond memories
Message 4 of 12
(4,175 Views)
what's right click? 😞
Message 5 of 12
(4,148 Views)
...right click with the mouse.  If you right click the array to cluster function you can set the size to something other than 9.
Message 6 of 12
(4,143 Views)
Using the right click opens up a whole new world for using LabVIEW. If your comment ess serious, you really need to stop what you are doing and take a couple of free tutorials or classes that come with a purchase.
Message 7 of 12
(4,113 Views)
He has to be kidding... I hope.  Because it would mean that he didn't understand how to use Windows with a mouse.  And the name make comments like these totally fair game.
Bill
CLD
(Mid-Level minion.)
Message 8 of 12
(4,091 Views)
To be fair he could be using a mac with one button.
Message 9 of 12
(4,085 Views)
Looks like w Windows background.  😉
Bill
CLD
(Mid-Level minion.)
Message 10 of 12
(4,079 Views)
