Array to Spreadsheet String VI truncating my rows
Sounds like a different problem. Can you show what you are seeing?
Tim
GHSP
Message 11 of 15
(1,438 Views)
Accepted by mechEmike
I only have hints, but let me take a completely wild guess.
1. You are using an old version of LV
2. You have modified the Write to Spreadsheet File VI to accept strings by following the suggestions on the BD
3.  There is a format string inside your modified VI which is truncating the strings (ie %.3s)
Message 12 of 15
(1,426 Views)
He did have to modify the function and the instructions do instruct you to change the default %.3f.
Message 13 of 15
(1,419 Views)
I was about 99% sure when I saw the screenshot with the old VI taking a string array, along with the fact that the default used to be %.3f.  Now I am at least 99.9% sure.
I'll modify my guesses as follows:
2. You have modified the Write to Spreadsheet File VI to accept strings by following most of the suggestions on the BD
Now I am up to 99.99% sure.
Message 14 of 15
(1,407 Views)
Got it. The format value that I thought I had changed was reverting to the default %.3f each time I ran the program. Thanks for all the help!
Message 15 of 15
(1,374 Views)
