Array threshold scan
I would like to scan the data in the Data.txt file from the last entry scanning up, and return the value of the x,y point the first time where the y data is closest to +100 or -100. Please see the graph.png file for clarification.
Any help will be greatly appreciated!
hiNi
(3,074 Views)
Accepted by topic author hiNI
I cannot get the negative threshold to work! So had to do some data manipulation.
But here is a working version, you can then do a compare to see which is the greater one.
If it was just positive numbers, threshold array function will also work. Here it is:
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(3,048 Views)
