Array select index by element
I got a 2D array with certain information about a product. The 2D array consists the product ID and a the amount of available products of that certain product ID. Now what I want to do is the following. I want to select the index of the array by using the element as a reference. Now my question is how can I do this? There are certain standards blocks that I could use when I wanted to select the element by using the index like Index Array. But I want to do the opposite. Is this possible?
Sorry about the other topics btw. Don't know how that happend Smiley Sad
Message Edited by Wouser on 12-14-2007 12:01 PM
(4,611 Views)
You'll use search 1D-array to search your first column/row (via Index Array with only one index specified) to get the index, then use that with Index Array to get the other info.
(4,603 Views)
Hello,  See the attached vi, I think it is what you are looking for.  If nothing else it may give you an idea of where to start.
Cheer!
(4,600 Views)
Thank you both for those fast replies. I will try to get it working now.
(4,592 Views)
