Array of float32!
Hi!
Is it possilbe to use arrays of float32 type in LabView or are all
arrays automatically float64?
I would like to create a buffer working like this:
- grow array until some size and do not allow further processing until array
is full
- when the array is full, allow the processing to proceede and then reset
the array
size
Looks complicated to me...
Thanks!
Atmapuri.
(3,633 Views)
The default is double (float64)
But you can create an array, then
right click on the array icon
Representation ---> select Single (float32)
(3,633 Views)
Right click on the array, or on the numeric within the array and under
the representation menu are the numeric choices, about ten of them
including float32.
> is full
> the array
> size
It sounds like you can do this either with one loop or two. You have
one piece of code adding to the array, and another that optionally
processes and empties. If using one loop, the code would consist of the
while loop with a shift register to hold
and recirculate the array. The
left side of the while loop would get the new data and add it to the
array. The middle of the loop would test the array size and wire the
results to a case statement. One frame of the case would simply pass
the array through and the other would process it and reset it. The
right side of the case would pass out the array and into the right shift
register. This solution is what I'd use as long as processing the data
is pretty quick and won't interrupt the next read too much.
The two loop solution has the creation of a queue outside the loops and
wire the refnum into both of them. One loop, the produces looks almost
like the one in the previous paragraph except in the case where you have
enough data, it would put then array into the queue element and enque
it. The other loop would wait for an element to be ready to dequeue and
then process it. This solution may be useful when the processing of the
data takes a highly variable amount of
time or would otherwise conflict
with the acquisition of the data. Using the queues will add some
overhead however, especially if the arrays are very large.
Greg McKaskle
(3,633 Views)
And yet another approach;
Look athe the queue functions.
Just push all of your data in as it arrives.
Somewhere else in the code check the queue size and read the entire queue if the size is what you want.
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(3,633 Views)
Hi!
Thanks. I need to pass an array of predetermined size and type
to the CIN sink. I was trying to figure out different approaches,
but the CIN holds a filtering code which reduces the sampling
frequency and whatever I do, I have to have a buffer somewhere
waiting until its full. (The output of the filter cant be one 1/7 of a
sample
for example).
The idea of buffers seems to be difficult to implement since the entire
Labview is per sample oriented.
Atmapuri.
(3,633 Views)
Ah. This is making more sense now. In that case, I'd recommend
wrapping the CIN into a subVI. You pass in the point and the while loop
I desribed earlier is inside the subVI. From the user of the subVI, it
looks normal, like it handles one point at a time. From the CIN point
of view, it only gets full buffers. The only complication added here is
that you may need something to initialize and flush the subVI buffer.
This is pretty similar to what happens in the point by point analysis
functions added in LV6.
Greg McKaskle
(3,633 Views)
