06-26-2008 07:34 AM
06-26-2008 07:37 AM
You can use Strings[] property of the ring control for that.
best regards,
Andrey.
06-26-2008 07:40 AM
06-26-2008 07:40 AM - edited 06-26-2008 07:44 AM
06-26-2008 07:45 AM
06-26-2008 07:46 AM
06-26-2008 07:51 AM
06-26-2008 07:54 AM
Hi Siva,
I am curious.
Can you tell us a little more about how 198 indicators are being used in your application?
We may be able to be of greater assistance if we knew a little more about why the count is so high and how they are being used.
Trying to help,
Ben
06-26-2008 08:00 AM
Hi, sivaramkumar,
I also will recommend to change something in your design. For example, if you need to visualize 200 elemenths in the same time, you can use the tables. If you need controls, then just imagine use case scenario, where one of 200 should be changed... How long time user will need for this action?
You can post your vi or screenshot of your front panel here and probably we will found better solution together...
Andrey.
06-26-2008 08:03 AM
