Array creation and usage - part 3
I am guessing there is an unwritten rule that states if you want to perform a constant operation on an array with multiple inputs you must connect the constant first. When trying to wire the output of an array to a multiply function and the array is wired first the constant for the other terminal wants to be an array also. For instance I wanted to multiply the array by 2.
jvh
(3,272 Views)
Accepted by jvh75021
You can either drop a numeric constant or drop the array constant and drag the constant out of it.  Just because you connected the array first, doesn't mean you can't operate with a scalar.
Go vote here to help change the current setup
Tim Elsey
Certified LabVIEW Architect
(3,271 Views)
Gets my vote.
(3,258 Views)
You might also want vote for my idea that would make some of these operations easier for the programmer. 😄
(3,221 Views)
