Array as counters??
The objective is to get the columns of data
data from column 0 = in one array
data from column 1 - in another array
.................until column n = in n array....
 Right now i do not have a better way , other than an array subset. But I would not know what my value of n would be as it's a GUI. The user has to specify a value. It could be any value.
Any feedbacks are welcome..
Message 11 of 18
(1,730 Views)
You want to create a separate 1D array for each column in your 2D array?
May I ask what the purpose of that would be?
Cory K
Message 12 of 18
(1,725 Views)
A  ' for loop' will only return my last value. If my user specify 8 elements in my array, then i'll only get the value at column 8. I suspect the way I constructed my 'for loop' might be wrong. That's why asking for help here...
Message 13 of 18
(1,720 Views)
Yes please answer that Q.
I am sensing you are trying to misuse array indicators and that is why we aren't "getting it".
Ben
Message 14 of 18
(1,718 Views)
To compare the values with another array . That other array is doing fine. So i didn't include that as part of my question here.
Message 15 of 18
(1,715 Views)
So do you actually need to display the data? Or do you just need to keep track of it for comparison later?
LabVIEW can keep that data in memory for use later without having to display it on the front panel
Cory K
Message 16 of 18
(1,710 Views)
''So do you actually need to display the data? Or do you just need to keep track of it for comparison later?
LabVIEW can keep that data in memory for use later without having to display it on the front panel''
Hi. You guys finally got my point. Thanks!! I knew i missed out something. How do Labview keep data in memory? This would be a much better option than displaying all the data. Any link or step by step tips on how to do that??
Message 17 of 18
(1,693 Views)
LabVIEW actually kept data in wire.
Therefore, if you wish to later use data in loop, you can keep it with "shift register".
But if you wish to use it in another loop, the simplest way is to display it, and using "local variable" to send data from display to another loop.
If you don't understand the term in quote, try searching it in ni.com.
Message 18 of 18
(1,649 Views)
