Array Subset type doesn't match for "case structure"
Hello
I am using an array and array subset to separate the values.
I try to connect array subset output to a CASE structure, But
I get an error: source is 1D array of unsigned byte and sink is…
What can be done to adapt the array subset to CASE structure?
Someone asked a similar question in the forum but I can't see an answer -
Yonatan
(1,650 Views)
Array subset as the name suggest creates a subset which is still an Array.
You can't connect a array of values to a case structure. You need an element of the array to wire to the case structure.
If you need to subject each element of the array subset to case structure, then put case structure inside for loop, index the array subset and feed it to the case structure.
Could you please explain why you're trying to do such a thing?
Santhosh
Soliton Technologies
(1,646 Views)
Accepted by rivlin
The output of Array Subset is an array.  A case structure cannot accept an array.  Instead of the Array Subset, use Index Array to pull out a single element.
(1,645 Views)
You can award solutions to more than one post.  (Strong hint.)
Bill
CLD
(Mid-Level minion.)
(1,611 Views)
