Array Shared Variable Element not written
Hi there,
I am using network published shared variables to communicate my host computer with a NI myRIO board, where real time control takes place. Everything seems to work properly, but when writing on a shared variable of type "Array of double" in the control loop, some values are not written (only the first 2 of an array of 7 are written), remaining as zeros.
The appearance of the block of this shared variable is slightly different from the others I have, and I don't know the reason. I attach the images of the appearances. Does anyone know why this would happen? It may be related to my problem...
Thank you in advance,
Miguel
Message 1 of 1
(2,222 Views)
